Road Racing - Replacement brake calipers
HioSSilver
02-19-2011, 10:43 AM
Are the any good ones that would be better than stock? I've looked and have'nt found much.
HioSSilver
02-20-2011, 10:57 AM
nothin available???
mattf2
02-21-2011, 10:16 AM
not sure about fitting on stock brackets, but the c5/c6 upgrade isn't too bad to do. You end up w/ about 1 more inch of rotor diameter.
If you're looking to upgrade your stock setup, get better pads, put in a good hi temp fluid, and install stainless lines.
SIK02SS
02-21-2011, 10:38 AM
StopTech makes a kit, Wilwood makes a kit, AP Racing makes a Corvette kit which I'm sure can be used, and Brembo makes a kit. Google is your friend on finding them all
HioSSilver
02-21-2011, 11:20 AM
That's why I asked the question..I found nothing. I don't want bigger rotors just a upgraded replacement calipers. I have a set of 15's for drag strip duties and still want to use them. I all ready have pfc pads SS lines. The pedal has been spongy for a while and that's what happens to our race cars when the caliper gets ware on it. I thought there might be a better replacement caliper availible.
SIK02SS
02-21-2011, 03:30 PM
not that will fit under 15s and they all require a larger rotor. have you bled the brakes? what do the rotors look like, uneven wear?
i don't know how you couldn't find any of them...
http://www.andysautosport.com/chevrolet/1998_2002_camaro/brakes/brake_kits/brembo/
http://www.streetbeatcustoms.com/StopTech/Big-Brake-Kits/Chevrolet-Camaro-StopTech-Big-Brake-Kit/797649/
http://www.streetperformance.com/part/wilwood-engineering/brake-conversion-kit/520955-140-7763.html
http://hardbarusa.com/hardbar/product_info.php?cPath=21_36&products_id=179
HioSSilver
02-21-2011, 04:56 PM
Yes I have bleed them. I don't want those because A: they won't fit under my 15's B: they're heavey.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
