CPS or MAF connector?
Old 02-19-2011, 09:06 PM
DRTHVDR's Avatar
Default CPS or MAF connector?
So there are two connectors on my L92 Truck harness. They both can plug into either the Mass Air Flow Sensor or into the Crank Position Sensor.
How Can I tell which is which?
Old 02-19-2011, 10:04 PM
Pocket's Avatar
For a truck harness the CMP and MAF connectors should not be the same. Trucks use a 5 wire MAF where Fbodys used a 3 wire that used the same body as the CMP, the CAM also fits. MAP uses a similar connector of the same series but the alignment tab doesnt fit anything but MAP sensors
MAF is PNK, BLK, YEL
CMP is LT GRN, YEL, DK BLU
CAM is RED, PNK, BRN
MAP is LT GRN, GRY, BLK or ORG
Old 02-20-2011, 08:34 AM
DRTHVDR's Avatar
They both are 5 pin connectors.
The two connectors have the following colored wires respectively:
Yellow, Pink, Black/White, Tan/Black, Tan
Blue, Brown, Blue/White, Purple, Tan
Old 02-20-2011, 09:02 AM
Jones'n's Avatar
Yel,Pnk,Blk/wht,Tan/Blk/Tan is the MAF/IAT
Blu, Brn, Bl/Wht, Ppl, Tan is the Cam position and VVT wiring (bottom of the timing cover, Dr side)
Old 02-20-2011, 09:33 AM
DRTHVDR's Avatar
Good...that's what I thought!!! Phew. So the Crank Position Sensor plug should be on the back of the harness near the Starter?
Old 02-20-2011, 12:57 PM
Pocket's Avatar
Right. Crank is 3 wire
Old 02-20-2011, 07:00 PM
DRTHVDR's Avatar
Thanks for the help guys.
Quick Reply: CPS or MAF connector?
