transmission and roadcourse
Old 02-19-2011, 09:22 PM
High_Angle's Avatar
Default transmission and roadcourse
how will my automatic trans from a 2002 WS6 hold up on a roadcourse? im planning on making 1-2 laps, spaced an hour or two apart
Old 02-19-2011, 09:34 PM
garygnu's Avatar
how many miles.change the fluid ,and add a deeper pan!
Old 02-19-2011, 09:36 PM
ULTIMATEORANGESS's Avatar
are stock PS coolers adequate for auto crossing?
Old 02-20-2011, 08:55 PM
Tainted's Avatar
get a transmission cooler for sure, that will help greatly. power steering sure add another cooler too for it if you can. the cooler you keep everything the better.
Old 02-21-2011, 10:39 PM
PBA
PBA's Avatar
Autocross gets the planetaties very hot, go with a better fluid such as Lubrication Engineers Monolec 7500 that will not thin out as easy as Dexron fluids will. Run this oil straight. I have seen a couple of laps take out this transmission with stock type oils. Always run a large external cooler.
