Arp crank bolt keeps coming loose???
Old 02-20-2011, 06:25 PM
mr_biscuitz's Avatar
Default Arp crank bolt keeps coming loose???
Any buddy have this happen to them and what did you do to fix it.
Old 02-20-2011, 06:29 PM
Turd Gen Guy
1nasty86's Avatar
Red locktite is your friend
Old 02-20-2011, 06:52 PM
Lt1Porsche's Avatar
Yep, what he said.
Old 02-20-2011, 06:55 PM
anheuserbusch08's Avatar
locktite FTW!!!!
Old 02-20-2011, 07:07 PM
slowride's Avatar
Is the damper spining? Mark it to make sure and pin it if needed. If the damper rotates counter clockwise it will break the bolt loose. I'd pin the crank and use a little red loctite. I know ARP wants you to use there lube, but it's not worth it if it backs out later (ask me how I know). When you need to remove the bolt you can heat it some to break down the loctite and it will come out easy.
Old 02-20-2011, 07:16 PM
Already using red loctite
Old 02-20-2011, 07:22 PM
S10xGN's Avatar
Use a torque wrench or recalibrate the one you have, the bolt isn't tight enough...
Old 02-20-2011, 08:24 PM
Turd Gen Guy
1nasty86's Avatar
I know it takes a man to tighten it down to what it needs. And since I started using the lock tite ive had no more proplems out of it
Old 02-20-2011, 08:27 PM
MyFirstLS1's Avatar
loctite is not really a solution to unproper torque, but i hope it holds. I would do the same if i didnt have access to a torque wrench that must be about 3-4 feet long in my shop
Old 02-20-2011, 09:13 PM
CamaroZ28_LS1's Avatar
250 foot pounds of torque should keep that ****** in there. I had a stock one come lose on me several times. Finally took my torque wrench and cranked it down to 250 like a bear in heat. No issues after that
Old 02-20-2011, 10:18 PM
Closed ex-Sponsor Account
Jon@HKE's Avatar
Like everyone else has said these don't really need loctite if you torque it properly but it's personal preference really.
Old 02-21-2011, 01:33 AM
Cold06's Avatar
LMFAO bear in heat hahahahahah!
Old 02-21-2011, 07:24 AM
melsie68's Avatar
Absolutely. ARP lube used here and no issues ever. Proper (manufacturer recommended) torque provides some degree of stretch on any fastener based on the material, diameter and pitch of the threads. The stretch is what keeps tension on the bolt and prevents it from backing out.
Old 02-21-2011, 08:34 PM
slowride's Avatar
I never had a problem with mine for years with arp lube and torque specs, but after I spun the damper on the road course I decided to all a little insurance and pin the crank and use loctite. I think the ARP lube with a pinned crank would have worked fine, but doing damper on a vette is a pain (for what it is).
Old 02-23-2011, 07:24 AM
Ive torqued this thing proper every time, First time a new stock bolt and went for a test drive, when I got back the bolt was gone. Then used Arp bolt with lube, then went to the loctite.
Old 02-23-2011, 05:21 PM
gnfan's Avatar
What value are you torquing the bolt to ? Just to be clear.
Old 02-23-2011, 05:54 PM
talon2008's Avatar
Clean the bolt hole out with a tap, sounds like you have some debris in the hole thats not allowing for the bolt to get completely tight against the mating surface.
Old 02-23-2011, 09:22 PM
slowride's Avatar
The damper press fit is probably loose. Does the damper go on easy or look like it has spun or gauled? What type damper is it?
Old 02-23-2011, 10:33 PM
99Bluz28's Avatar
I agree, take the TW in for calibration, because it sounds like the crank bolt isn't being tightened enough.
Old 02-23-2011, 11:04 PM
Turd Gen Guy
1nasty86's Avatar
Just dip the whole bolt in red locktite and then install it. If that fails I have a welder
Quick Reply: Arp crank bolt keeps coming loose???
