Pontiac GTO 2004-2006 The Modern Goat
Complete ProCharger D-1SC Systems at Brute Speed
Old 02-21-2011, 06:12 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Default Complete ProCharger D-1SC Systems at Brute Speed
http://shop.brutespeed.com/ATI-1GN20...-Speed-Kit.htm
2004 GTO
http://shop.brutespeed.com/ATI-1GN30...-Speed-Kit.htm
2005-2006 GTO
Check them out at the above links, prices include shipping! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 02-24-2011, 08:19 AM
N2OBaby's Avatar
Question
Nice Bob@BruteSpeed.
Is it true a F1 Procharger will fit where a P1-SC or D1-SC fits?
Old 02-24-2011, 08:21 AM
LS1Tech Sponsor
Thanks, yes it is true.
Take a look at this build that we did back at the old shop, where we used a GTO bracket on a CTS-V. http://www.exoticperformanceplus.com...Car.php?car=29 Bob
__________________
Old 02-24-2011, 11:45 AM
serik21's Avatar
Are you selling kits for the cts-v?
Old 02-28-2011, 04:03 AM
S2VYSS's Avatar
Whats the cost for a 2004 GTO kit?
Old 02-28-2011, 04:25 AM
LS1Tech Sponsor
No I'm not. We did at EPP but we found it was best to do them in house only, so we dropped the CTS-V as a kit. Thanks for asking. Bob
__________________
Old 02-28-2011, 04:26 AM
LS1Tech Sponsor
$6,399.99 shipped in 489 US States
What is included:
* ATI 1GN202-SCI D-1SC High Output Tuner Kit
* Siemens 60lb Injectors
* Lingenfelter GTO Fuel Pump Assembly
* ATI Performance Products 918853 Harmonic Balancer
* ATI ProCharger crank pinning kit
* NGK TR6 pn#4177 spark plugs
* FREE SHIPPING!!!!
* All you need is to get the car tuned once the system is installed!
Link to this kit.
Thanks for inquiring. Bob
__________________
Old 02-28-2011, 04:28 AM
S2VYSS's Avatar
What size pulley does the kit come with?
Old 02-28-2011, 04:31 AM
LS1Tech Sponsor
There is no set pulley, as I take into account the customers build and elevation when I take the order.
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
Let me know if you have any questions. Free shipping is for 48 US States. Overseas shipping is available. Thanks! Bob
__________________
Old 02-28-2011, 04:45 AM
S2VYSS's Avatar
Thanks for the reply Bob, gave me alot to think about
Just in general, what kind of a power are you seeing on stock bottom end LS1's?
Old 02-28-2011, 04:53 AM
LS1Tech Sponsor
You're welcome. On a basically stock LS1 at 8 psi you can expect to see an average increase of 140 rwhp. Thanks. Bob
__________________
Old 01-23-2016, 08:07 AM
LS1Tech Sponsor
http://shop.brutespeed.com/04-06-GTO...stems_c566.htm
All info on the GTO kits has been updated. Bob
__________________
Quick Reply: Complete ProCharger D-1SC Systems at Brute Speed
