can i drive it like this to tuner
Hi need opinion, i have a 402 that had Racetronics tri-cone spray 42lb injectors, i have changed them to bosch green giant 42lb injectors(because i changed intake, fast 102 from ls6 and my racetronics would not clear the fast 102), will this hurt the pcm or anything else until i make it to the tuner?
you should be ok, just dont dog it and keep the rpms as low as possible. I am not expert so it might be better to hear from one. i dont see a big issue you went with the same pressure injectors, the bigger intake wont hurt things either, the computer will compensate a little for lean and rich mixtures.
