P0102 code not going away help!!!
I have a 2002 z28 35th anniversary camaro and it has just recently started studdering at a low rpm (under 2800 rpm) the code its throwing is a P0102 which is a MAF sensor code and i changed the MAF and it didnt fix a thing. I really need help if you have any ideas please post up
Save the manuals!
Did you read the link above? Your problem is electrical - not mechanical. (BTW - The only way your lid would be an issue is if a dead animal, etc. were in there and blocking airflow.) If you changed the MAF, then you have a cut or unplugged wire somewhere.
You should start measuring the voltage at the sensor plug and then work your way back through the circuit until you find the break.
Save the manuals!
Three wires:
Yellow - Sensor Signal
Black/White - Ground
Pink - Ignition Feed
With the ignition on but the engine off, you should see 5V between the Yellow and Black/White wire.
The factory manual has a very long procedure for testing the circuit, which involves testing the PCM and electrical frequency from the sensor, etc.
The manual also says that the code can be set by:
- Broken wires
- Engine vacuum leaks
- PCV leaks
- An incorrect PCV valve
- Missing engine oil fill cap
- Unseated engine oil dipstick
- Broken wires
- PCV leaks
Three wires:
- Broken wires
- PCV leaks
- Broken wires
- PCV leaks
http://www.ls2.com/boggs/dtcs/DTC%20P0102.htm
