LQ9 vs LS2 bottom end
Old 02-22-2011, 07:58 AM
sman's Avatar
Default LQ9 vs LS2 bottom end
Aside from the block and heads, are the lq9 and ls2 essentially the same? Same bore, same stroke, both have flat top pistons.
What if any are the differences?
Old 02-22-2011, 08:08 PM
sman's Avatar
No one.......
Old 02-22-2011, 08:20 PM
Prorac1's Avatar
Hey spencer. I dont know what the differances are, but I do know that the two rotating assys WILL interchange size wise. Thats all I got pal. Good luck. Eric L
Old 02-22-2011, 08:22 PM
Prorac1's Avatar
And IIRC it wasnt until the LS3 gen IV that they went to floating wrist pins. Eric L
Old 02-22-2011, 09:13 PM
sman's Avatar
Thanks! Guess I could have just thrown this up on mifbody.com huh? Lol
Old 02-22-2011, 09:29 PM
NemeSS's Avatar
Ls2 is gen4
Lq9 still gen3
Lq still has "distributor hole" cam reluctor sensor
Ls2 has reluctor cam sensor pickup on the timing gear sprocket. Later ls2 are 58x
Old 02-22-2011, 10:00 PM
sman's Avatar
I knew that stuff, was really just concerned with bore, stroke, and pistons dimensions.
What im really getting at is, does putting 243s on a lq9 ESSENTIALLY give you an iron ls2?
Old 02-22-2011, 10:05 PM
outkast6991's Avatar
yes. i'm running that exact set up
Old 02-22-2011, 10:29 PM
sman's Avatar
Exactly what I wanted to hear, picked up an lq9 this past weekend and getting 243s tomorrow after work.
With the TR224 and other mods in sig, what do you think it will put to the tires? 390?
Old 02-22-2011, 11:18 PM
ss454327's Avatar
Easy answer...yes. The differences were minute but around '05 the LQ9 started using the rotating assembly from the LS2...which was supposed to be stronger.
Old 02-22-2011, 11:47 PM
ovaboost's Avatar
It would be a heavy "LS2"
Old 02-23-2011, 12:02 AM
dug
dug's Avatar
wont the compression of a lq9 with 243 heads be higher than a ls2?
Old 02-23-2011, 12:41 AM
caddy03pimpin's Avatar
The 05+ LQ9 has the same pistons, rings, rods, crank (minus the reluctor), timing chain/sprocket as a LS2.
Old 02-23-2011, 12:56 AM
Thefastguys's Avatar
the compression wouldnt be any different if you were using ls2 heads with a lq9 block.
its the same as an ls2 just about 100 pounds heavier i beleive.
Old 02-23-2011, 06:11 AM
sounds about right i would think. torque should be up there as well
Old 02-23-2011, 09:27 AM
dug
dug's Avatar
whats the compression ratio of the ls2?
Old 02-23-2011, 09:33 AM
redtan's Avatar
10.9 comp
Old 02-26-2011, 10:06 PM
94Conv's Avatar
I was told that the LS2 rods/pistons will stick out of the block .005 farther on the iron block, than on the AL... haven't checked it, but it would be worth checking if you are milling or using thinner head gaskets.
Old 04-06-2011, 11:06 AM
fastsspr's Avatar
What cam are you using?
Old 04-06-2011, 11:24 AM
dug
dug's Avatar
does anyone know what a stock ls2 dynos with all the bolt ons but with the stock cam?
Quick Reply: LQ9 vs LS2 bottom end
