Pontiac GTO 2004-2006 The Modern Goat
Smashed up Goat.
Old 02-22-2011, 12:07 PM
chevbon's Avatar
Default Smashed up Goat.
Okay, so here's my deal, I am looking for an LS1 on a budget. I was looking at a GTO that is a bit crumpled. The front bumper is off of the car, the door has a big dent in it and the front fender is crumpled up. The car will also need a headlight. Pending no frame damage, this is all repairable. Correct? The only reason I ask is because my dad is an old school mechanic and he thinks I'll never be able to fix it because "All new cars have the unibody construction." Just wanted to know about the difficulty of this fix. Thanks.
Old 02-22-2011, 01:06 PM
05raptorle's Avatar
should be... Have any pictures of the damage? replacement parts for GTO's can be pretty spendy and some times hard to find.
Old 02-22-2011, 01:28 PM
yfz
yfz's Avatar
I was looking into buying an 06 gto that was totaled and needed a front clip, lights and possilby the frame rails straightened and the costs of the parts is was turned me off. I believe the price of an aftermarket hood for my cost (worked at a body shop) was like 1200 dollars. This for an ls2 hood though.
If there is frame damage you can take it to a body shop who has a frame rack and they will tell you if it needs straightened and if so, they will get the fenders and hood to all line up right. Could cost quite a bit in labor.
Old 02-22-2011, 02:17 PM
chevbon's Avatar
Don't have pics unfortunately. It doesn't look all that bad though. From a little research it looks possible for under a grand
Old 02-22-2011, 02:37 PM
tom's2005gto's Avatar
almost anything an be fixed. If your able and willing to do the labor yourself, and buy used parts it MIGHT be worth it.
Old 02-22-2011, 02:53 PM
chevbon's Avatar
Ill be doing the labor myself. This is the only way that I can afford a GTO right now.
Old 02-22-2011, 04:39 PM
chevbon's Avatar
What is involved in straightening the frame? Removal of engine and trans?
Old 02-23-2011, 08:35 PM
04gto5.7's Avatar
no u will just have to take the car into a body shop and they will but if on a frame machine and they will tell u if its bent or not and unless its 100% noticable thats the only way u will know
Old 02-23-2011, 10:20 PM
chevbon's Avatar
How much does something like that cost?
Old 02-24-2011, 07:31 PM
larry941's Avatar
i have a lot of used gto parts lmk if u buy the car and neat somthing thanks
Quick Reply: Smashed up Goat.
