monster level 3
Old 02-22-2011, 06:42 PM
bh353's Avatar
Default monster level 3
anyone having a problem with squeeling when letting the clutch out? the first 5k miles it didn't make a sound. Now it sounds horrible.
Old 02-22-2011, 06:45 PM
jeepers_88's Avatar
did you replace the throwout bearing when you did your clutch?
Old 02-22-2011, 06:53 PM
bh353's Avatar
new throw out bearing..it makes the sound when it makes contact with the pressure plate and flywheel.im about ready to pull it out and go with a different brand.
Old 02-22-2011, 07:01 PM
jeepers_88's Avatar
How long have you had it for? I would give monster a call and see if they have any feedback. They are good guys to deal with.
Old 02-22-2011, 07:07 PM
bh353's Avatar
it has right around 5k on it if that..i daily drive it so its probably glazed.it dosent slip but it make that terrible sound and its embarrising.
Old 02-22-2011, 07:26 PM
adrynalinjunkie's Avatar
My monster 3 does it to. Usually only when it is cold. Clutch holds great though. I probably have 7k on it
Old 02-22-2011, 07:32 PM
Zturd's Avatar
I've heard of this before actually with a spec clutch my friend had in his C5. Being I hate spec and their customer service it pains me to say when cold out the clutch made noise yes. However it held in his near 600rwhp car for 3 years and 20k+miles I'd be willing to bet your clutch is gonna do the same thing.
Old 02-22-2011, 07:35 PM
bh353's Avatar
mine does it when it's hot.when cold dosen't make a sound.
Old 02-23-2011, 11:58 AM
11Second Club
Gauge's Avatar
This is a common problem with single disk clutches rated to handle lots of power. Monster's typical response to this is that there's a glaze built up on the friction disk and that you need to go beat the **** out of the clutch to wear it off. I've had similar experiences with a Textralia, and a few hard launches at the track cleared up the squeal and the chatter.
Old 02-24-2011, 03:34 PM
SNLPerformance's Avatar
As stated above it probably just needs a little TLC if that doesn't take care of it, give us a call and we can discuss some ways to adjust your driving so it won't happen. Chris 817-750-2000
