wont crank
Old 02-23-2011, 05:44 PM
mike.d's Avatar
Angry wont crank
went to start car it wont crank over relays good got 12.4 volts from batt. needles in gauges will bounce with car shut off obd port not working .fuel pump is priming any ideas what is causing this thanks
Old 02-23-2011, 05:51 PM
flame's Avatar
VATS Anti theft........what vehicle and year?
Old 02-23-2011, 05:59 PM
mike.d's Avatar
02 trans am
Old 02-23-2011, 06:12 PM
LeftySS's Avatar
Weird! I just went to start my 99 SS and mine is doing the same thing. Everything comes on like normal, turn the key and nothing. Security light is on so I figured it was the VATS. How to fix?
Old 02-23-2011, 06:37 PM
mike.d's Avatar
my security light is not on could it be vats anyway
Old 02-23-2011, 07:15 PM
LeftySS's Avatar
Not sure. I tried my other key and it started the car. This is the first time in 12 years the car has done this. Strange!
Old 02-24-2011, 11:50 AM
flame's Avatar
Probably not VATS if the security light is off. Try it in neutral instead of park.
Old 03-09-2011, 02:12 PM
mike.d's Avatar
car started twice but cranked very slow put battery back in stock location replaced battery cables car started but was missfireing shut car off now wont crank needles in gauges bouncing again any ideas
Old 03-09-2011, 03:53 PM
bigboykilroy's Avatar
clean the security pellet on the key.
Old 03-09-2011, 04:03 PM
mike.d's Avatar
replaced key and did bypass didnt work security light not on
Old 03-10-2011, 10:22 AM
BlueThunder2's Avatar
Make sure your battery has a full charge. Typically, if the gauges are acting up and the security light is not on, it is a battery problem. Sometimes, a battery will even have enough juice to turn the starter over, but not enough to fire. Check battery charge, then let us know what happens.
Old 03-10-2011, 02:57 PM
mike.d's Avatar
just put in a brand new battery same problem
Old 03-11-2011, 05:58 PM
samsdad's Avatar
Default Same Issue 2000 V-6 Firebird Won't Start
Must be the season for gremlins. My car will start when I jump the solenoid but
only runs for a few seconds. I tried the VATS bypass didn't make a difference.
Suggestions?
Thanks
Mark
Old 03-11-2011, 06:50 PM
Check your fuses under the hood. You might have a blown fuse.
