Help with 98 T/A fuel pump!
Hey guys, my bro's T/A needs a fuel pump! Hes not working right now so money is tight... he said auto zone told him $400 for pump...he said he found one on ebay for $90 without the housing or somthing. Can he just buy the pump like that and use the old housing, I havent done a fuel pump on a 4th gen before so not sure about this. Any help with this would be great thanks! This needs to be done as cheap as possible.
idk bout that but if u want it done cheap take the carpet cover in the trunk off and then in the middle where the carpet was slice a hole the pump will be right there and then duct tape it back up after u finish it. takes about 10-15 min to do this and be done with it.
You could use a generic walbro, or you could have a full plug and play solution from racetronix! We only use genuine Walbro's in all our assemblies.
If the car is factory or only a few mods, you can use the $107.10 Racetronix factory upgrade pump.
http://www.racetronix.biz/itemdesc.a...PA-017&eq=&Tp=
If he plans on more mods in the future might as well get the 255lph now! Better than doing it twice!
http://www.racetronix.biz/itemdesc.a...PA-002&eq=&Tp=
