normal wear on 0z700?
Old 02-24-2011, 08:09 PM
ajw2500hd's Avatar
Exclamation normal wear on 0z700?
ok i have a textralia 0z700 clutch that i got in september 2010 with less then 1000 miles on it and it does have a tick master
98 camaro all motor no power adders, does this look like normal clutch wear for 1000 miles
Attached Thumbnails normal wear on 0z700?-clutch1.jpeg   normal wear on 0z700?-clutch2.jpeg   normal wear on 0z700?-clutch3.jpeg   normal wear on 0z700?-clutch4.jpeg   normal wear on 0z700?-clutch7.jpeg
Old 02-25-2011, 12:15 AM
BarneyMobile's Avatar
That looks like a hard 1000 miles on that clutch. It looks like the clutch isn't fully broken-in. The outter edge looks like it being over heated from not making full contact with the flywheel. The pressure plate sided doesn't appear to be as bad.
Old 02-25-2011, 11:41 AM
C5kid's Avatar
I would just call it a day and put a Turbo400 in the car. Come on Buck Angel, you know u wanna.
Old 02-25-2011, 11:44 AM
ajw2500hd's Avatar
lmfao **** that ****!!!!! no overdrive? hell no thats boring anyway and if i do go auto i will wax mikep then after i had some spray and that wouldnt be nice!!
Quick Reply: normal wear on 0z700?
