18 inch wheel question
Will I need wheel adapters for the wheels below?
285 40 18 nittos in the rear is what I was thinking....what tire size should I run up front?
http://www.lakeshorewheelandtire.com...o-c6-zo6.shtml
Chrome C6-ZO6 Style, 18 inch
18x9.5 inch , 5x4.75 inch 50mm
Chrome Wheels
# Fits 1993-2002 Chevy Camaro
# Fits 1993-2002 Pontiac Firebird
# $869/set
# Brand New Reproduction C6-ZO6 Style Wheels
# Center caps are included.
In Stock
53531D-c
Chrome Wheels
# $869/set
In Stock
53531D-c
since the rims r the same all around, use the same size tire, so u can rotate them... 275/35x18 (stock diameter, 25.7")
u could use a 285/35 (25.9") or a 295/35 (26.1") in the back with the 275/35's up front...
285/40x18 is 27" tall...
mine are 17 but fit 275 just right on 9.5 width. i also want 18x10.5 all around. used to run a 18x10.5 on my 240sx with a 235/40 lol streched a bit. need more meat with th ls!
Location: Oklahoma City, OK/North Long Beach/Paramount, CA
18x9.5 all around i would do 275-35-18's or 285-35-18's front and back for the benefits of rotating my tires front to back for more usage but if u dont care for that and want a staggered look with tires than run a 275-35 front and 285-35 rear a 40 series tire would work to but if your lowered you might rub
damn 18x10.5 on all 4 corners on the 240 sheeesh im sure it looked sick was it slammed. i had a maxima with 19x9.5's all around slammed w/ stretch tires 235-35 lol
So i am going with the 285 35 18 Nitto Drag Radial in the rear for sure....But up front, i am a little indecisive wouldn't it be better to go with a tire that isn't as wide so that their isn't any rubbing?
I'm thinking 215/35ZR-18
