4 7 cam lobe swap
Old 02-26-2011, 11:35 PM
gregrob's Avatar
Default 4 7 cam lobe swap
I'm getting ready to have a new cam cut. Should I bother with it
Old 02-27-2011, 01:17 AM
93Z2871805's Avatar
Why not? The "Corvette" firing order works.
Old 02-27-2011, 01:27 AM
hitmanws6's Avatar
Ive always heard it helps, never heard it hurts, it do it
gregrob's Avatar
I heard it puts less stress on the crankshaft by means of less deflection
Anyone got a technical explanation
Old 02-27-2011, 01:33 AM
93Z2871805's Avatar
It's more dynamically stable, basically the OEMs (Ford) figured out by switching the firing order and better matching the companion cylinders the engine would last longer (and make a little more power).
Old 02-27-2011, 01:48 AM
93Z2871805's Avatar
Ideas include, it cuts down on reversion, it makes power due to how the crank flexes dynamically (and if you had a billet crank it wouldn't work at all), and it makes the motor run smoother. There's no real 100% concrete evidence in how it works. It just seems to work in most cases for the better. You will need tuning for your computer to accept it though.
Old 02-27-2011, 02:05 AM
gregrob's Avatar
I dont know why you would have to retune...
Just swap 4/7 injectors and plug wire I would think
Old 02-27-2011, 02:16 AM
93Z2871805's Avatar
Ignition wires and injector wires both would need to be swapped. I just don't know what other metering events would be affected by a bank to bank swap.
Old 02-27-2011, 02:36 AM
jester1614's Avatar
I dont see why a tune would be necessary, as long as the new 4 and 7 spark plugs, and injectors fired when commanded. unless the bank to bank swap effected the o2 sensors
Old 02-27-2011, 02:40 AM
Wicked94Z's Avatar
you wouldn't have to swap injectors, you can customize injector firing depending on the efi you're running. stock computer obviously out, optispark obviously out unless you wanted to run some funky *** ignition wires all over the place lol. i don't know how many step nose cams you can get on a 4/7 core though
Old 02-27-2011, 02:43 AM
gregrob's Avatar
Im going to see if Bullet can do it, if not then Im not going to screw with it.
Old 02-27-2011, 09:27 AM
joelster's Avatar
It pays dividends on larger cams, and is unnoticeable on cams that are smaller. You almost never see them on cams with less than 250 degrees @ .050". My friend has one in his 383 drag car. It sounds awesome. It has a higher pitch to the motor when he revs it.Not really sure why.
Old 02-27-2011, 01:18 PM
GIZMO's Avatar
Bullet can do it, but I really doubt that you will see worthwhile gains.
Old 02-27-2011, 02:47 PM
gregrob's Avatar
If theres a chance it will be easier on the crankshaft, why not do it?
In my research the gains are questionable, but I havent' found any negatives. If there are possible negative effects though I wont bother.
Old 02-27-2011, 02:57 PM
05HD's Avatar
I think the OEM firing order is marginally better at even cylinder filling from an LT1 type intake manifold.
Old 02-27-2011, 06:54 PM
GIZMO's Avatar
So far, I have never hurt a stock crank in any way.
In my research the gains are questionable, but I havent' found any negatives. If there are possible negative effects though I wont bother?
No negative effects that I know of, but I haven't seen any real gains in an LT1 Stocker. We dropped the idea after some testing a few years ago. Talk to Bullet. They may have better things to say.
Old 02-27-2011, 06:58 PM
gregrob's Avatar
Will do.
Thanks
Old 02-27-2011, 07:03 PM
IAMWAYHIGH's Avatar
Hot Rod did this sorta thing a few years ago and it got them 5-15 horse, unsure what your thinking you'll get but if you're swappin cams to a bigger one, this firing order swap would help even more. When I get some cash for a cam and the other stuff I'm totally doin that sorta swap.
Old 02-27-2011, 07:08 PM
93Z2871805's Avatar
I'd think by pairing 4 and 2 to draw at the same time instead of 5 and 7 to draw at the same time (paired cylinders at the front closer to the TB instead of at the back of the manifold) theoretically it would put the air source of a factory manifold more in favor of the 4/7 arrangement. Chevy did it for a reason on the LS1, maybe that's it. Just a theory though.
Old 02-27-2011, 07:28 PM
05HD's Avatar
I was thinking that 7 and 8 next to each other would be worse than the benefit of the 4 next to 2 swap. Never mind that 4, 2 and1 are all in a row. I think the center cylinders (3,5,4,6) are fed the best by the LT1 intake and that is where the adjacent pairings are with the stock firing order.
Quick Reply: 4 7 cam lobe swap
