getting into the 12s
I have a 93z28 that runs 14.3 all I have done to it is the cat taking off and a flow master muffler I'm wondering what I need to do to get into the 12s any advise would help
1 Post
Its pretty simple with the LT1 cars, first make sure your car is tuned up, plugs, wires, etc. Seafoaming the car to remove any buildup is a good idea too.
Then a cold air intake, exhaust, drag radials should put you there or at least close. Practice launching too at the track. You can put all the money you want into the car, but if you cant drive it, you arent going to get good times.
If you havent broken into the 12s yet, a stall convertor, headers, and a tune will definatly put you there. After that bolt ons will continue to lower your times, 1.6 rocker arms, 52 mm throttle body, suspension upgrades, weight reduction, a cam, and it all goes downhill after that lol Just start simple and keep upgrading until you are content with your times...if ever
I was getting a 2.1 60 ft on street tires I'm pretty good launching f body's this is the second one I've owned my first was a 11sec T/A ls1 this the fist lt1 I've done the tune up and it has a new map sensor iat iac and tps I will seafoam it when I do my next oil change I forgot to mention that when I ran that time the map sensor was acting up really bad
Village Troll
Not sure what your budget is...
Reputable ported cylinder heads like LPE, GTP or AI, LT's, ORY and DR's. No need to change out gears, same driveablity as stock with far more power and a big time sleeper.
Depending on your budget, I'd go for the most cost effective mods first. Gears, stall(if auto), and exhaust had me in the 12s with no problem. 6 speeds are little more tricky, but with launch practice, can get in the 12s as well with sticky tires. Then on to EWP, RRs, and good tune for 12.30s-12.50s. If you want an even lower ET on bolt-ons, start stripping it down. The bolt-on record is 11.48, so use your imagination.
