ABS delete????
Old 02-27-2011, 11:05 PM
fastredlt1's Avatar
Default ABS delete????
95 formula lt1. Im going to delete the ABS and use the SJM kit. Do i need to use the stock brake lines or does it come with new ones??? My lines are stripped where the threads go into the ABS system, cant get them out. Can i just cutt them???????
Old 02-27-2011, 11:24 PM
airfix's Avatar
Do you have the kit yet? It comes with instructions that have pictures and shows you where to cut the lines. overall it's a pretty easy install.
airfix's Avatar
Also if you do a search you can see where everyone cut their lines
Old 02-27-2011, 11:43 PM
fastredlt1's Avatar
no i dont have the kit yet. just trying to get the ABS out of the way, need to paint the engine compartment. do you know where i can finds the pics???? thanks for the help.......
Old 02-28-2011, 02:07 AM
Village Troll
SS RRR's Avatar
Do a search for SJM Kit in the Suspension/Brakes forum.
Old 03-01-2011, 11:53 AM
AChotrod's Avatar
you reuse some of your stock lines but not the ones from the master to the abs block
Quick Reply: ABS delete????
