4l60e Boost valve Location! Pulling my hair out!
Ok I got my 4l60e in a 97 chevy blazer 2 dr 4x4, I know sry guys no ls1, I joined because all of the information on the 4l60e and mods, I am new to tranny mods and have been doing a lot of good reading on this site!
Anyways I am about to order a vette servo and booste valve because thats what everyone says is the easiest mods to start with. Well I have searched all day and cant find the location of this? Does anyone have any pics? I can replace this just by removing the pan right? I also was thinking of replacing the pressure control solenoid as I read that needs to be replaced every 50k? Anyways I circled where I think the pressure control solenoid is can someone verify this and also point out where the boost valve is or a pic or a tutorial anything! THAnks. I think I am going to order the .471? Any tips on size would also be appreciated!
Note I cant circle the pressure control solenoid but it is on the very top of the picture towards the left corner the big black cylinder.. is this correct and please where is the boost valve?
and omg lol this is great >
But I cant install that myself... I was looking at the superior shift correction kit, what labor be on that or the trango kit, I have looked at the hd2 but the tranny has to be pulled to install everything I thought... basically until I swapped my fluid when I came to a stop and accelerated hard my engine would rev up and then slam into gear unless I accelerated lightly. It hasnt done this in like a week so hopefully just a dirty valve cleaned by new fluid. Does this sound like anything else familiar? thanks man!
And where is the boost valve? lol
you can remove the boost valve while trans is in car its in the pump on the driver side of the filter it has a small internal snap ring that you have to remove and it will fall out after that.
boost valve and shift censors 4l60e transmission
http://www.msgpio.com/manuals/mshift/operation.html diagram of shift censors
boost valve is on right side of censors in pic
Moderator
Do you mean installing a boost valve and replacing the shift solenoids?
If yes, this is at most 15 minutes more than doing a fluid change.
The Sonnax 4l60E-LB1 is a good choice for a boost valve; a shop can order it overnight from their distributor. (Note: somewhere around 2005/2006 the 4l60e-LB2 is needed.)
Moderator
