1967 camaro I need a little help
Old 02-28-2011, 09:00 AM
sic7camaro's Avatar
Default 1967 camaro I need a little help
I was about to buy a oil pan and gas tank for my camaro but wanna make sure I get the right part.im using trans dapt 1inch set back plates edelbrock headers.qestion I got will a f-body camaro oil pan work with my set up?what gas tank can I use?or hVe u guys used ?plan on makn 500hp na.lq4/ls3 heads.th350.12bolt.any part number would help also where u got parts from.also im using f-body front acc's.thanks for the help
Old 02-28-2011, 10:01 AM
bmf5150's Avatar
I went with autokraft oil pan,but I'm using S&p
Motor mounts!!I went with the ricks gas tank!!
Old 02-28-2011, 07:32 PM
JAY ROD's Avatar
I used an F body pan,stock tank with external walbro 255 fuel pump.
Worked great.
Old 02-28-2011, 07:42 PM
sic7camaro's Avatar
^^^did u mod. The oil pan to fit??
Steve68's Avatar
ATS mounts and trans crossmember, ATS is now SpeedTech
Ricks Vapor Works Tank on order!! from L&H customs
Modified my own pan! Joe the welder!!
Old 02-28-2011, 08:56 PM
zamora7's Avatar
I wouldn't use the Trans-Dapt plates, some people had trouble with them so I returned mine and got the ones from Carshop.
Old 03-01-2011, 09:42 AM
sic7camaro's Avatar
whats the difference?
Old 03-01-2011, 11:52 PM
flyinsquirel's Avatar
Search for my posts & you'll find some pics of an f-body pan with Edelbrock mounts. Though I hear they aren't making them any more. Sure you could make some of your own pretty easily though.
Quick Reply: 1967 camaro I need a little help
