80# mototron injectors high imp.
Old 02-28-2011, 11:07 PM
madmax4499's Avatar
Default 80# mototron injectors high imp.
is there such an animal at 43.5 fuel press. or will they be 60# injectors with more base pressure.
im asking because i am planing on running a return fuel system with a set base pressure, then 1-1 rise with boost.
i need to support approx. 1100 rwhp. "edit." 800 rwhp? Im asking questions because i dont know.
Old 03-01-2011, 08:05 AM
Coal Mining Director
onfire's Avatar
80's are wayyyyyy too small for 1100rwhp.
Old 03-01-2011, 08:04 PM
bad6as's Avatar
fic makes a 103lb at 58psi and at 43.5 their about a 95 lb
Old 03-01-2011, 10:17 PM
madmax4499's Avatar
thanks for the reply, so for what im doing i would set base press at 43.5 and let the regulator 1-1 with boost? i assume the 58 psi is stock rail pressure with out a return regulator.
I will start my build thread friday. this is my first LS build, been modding cars for 25 years,
Old 03-01-2011, 10:21 PM
bad6as's Avatar
Even thoe its 1-1 you might not get 15 psi increase in fuel pressure with 15 lbs boost.
Idealy at max power you want to be around 80% duty cycle. So work it till you get that and your base pressure is what it is.
Old 03-02-2011, 10:26 AM
madmax4499's Avatar
that helps, so, give it what it wants.
Old 03-02-2011, 10:29 AM
bad6as's Avatar
Yeah my new 95 lb at 43.5 injectors should be here in a day or so. and ill have it on a dyno within a month. Ill let you know what I find
Old 03-03-2011, 03:05 PM
madmax4499's Avatar
sounds great.
Old 03-03-2011, 06:36 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
As an FYI... the 80# Mototrons do flow 80 at 43.5psi.
And yes they will support 800rwhp.
Old 03-03-2011, 06:52 PM
madmax4499's Avatar
Great, do you sell any in line pumps -8 in and out?
Old 03-03-2011, 09:23 PM
LS1TECH Sponsor
I have access to many different pumps. Please call to discuss your options.
