Umi Tunnel Mount TRUE DUALS
Could someone with an UMI Tunnel mount TA with DSL tell me if this will work?
As you can see from the illustration the narrow portion is less than 5 inches.
If someone could measure and tell me if this will fit under / through the brace I would be forever grateful
i guess it wouldnt be too bad but it seems like the crossover area seems kind of long/big which will slow the velocity of the exhaust which is counterproductive. Since the exhaust is not a steady stream it is pulses you want to use the low pressure behind one pulse to pull the next one through the x pipe.
True but when you get that far back in the exhaust, it's been shown having a box to terminate the pressure waves is a benefit to flow as well.
I guess we'll see how this works. If it dynos uber low I'll pull the duals off and make a hero pull with open headers
I really think it's splitting hairs comparing this to the conventional X pipe though.
Yay Borla Pro XS. What about the Magnaflow Tru X or my Thunderbolt X? Thats what I have on mine
http://performance-curve.com/Product...nmex-xpipe.jpg
