Newbie Help! Yank SS3200?
Old 03-01-2011, 03:00 AM
Ghost99's Avatar
Question Newbie Help! Yank SS3200?
Want to stall my car and i wanted to know if a Yank SS3200 with a B&M Tranny Cooler (29,200 BTU) would be a good setup with stock 2.73 gears?? When i do this will i need anything else for the install or just the torque converter and tranny cooler?(I will be having it installed professionally)...Any help would be appreciated, Thanks!
Old 03-01-2011, 09:07 AM
senicalj4579's Avatar
Im still waiting for the ss3600 for my 3.23 car.
Well you might wanna go with a new flexplate but if your car is a 99 then you maybe alright. I had to buy a new one because I have the 01-02 pos plate that might break. I got the newest replacement plate from GM. Its not SFI rated but it was recomended by Yank and plenty strong enough.
I would say you need to put some gear in there (3.23-3.73) and go with a ss3600. But if you dont wanna do gears then the ss3200 would probly be a better match for your car but you need to call Dave at Yank and he will inform you.
Most will tell you to go bigger but call dave and he will tell you what the best all around converter will be for your car/gear/power ect...
Old 03-01-2011, 09:38 AM
FirstYrLS1Z's Avatar
98-02 LS1 A4s' had 2 varieties of flexplates,the earlier ones with round holes seem to be holding up,the later ones with 'peanut' shaped holes are having problems.
Old 03-01-2011, 10:03 AM
lemons12's Avatar
Imo you won't notice the difference between a 273 gear or 323 while driving around.
I recommend going with a 3600. Won't be a noticeable difference, 100 rpms or so around town, but will cut a muh better 60 with much better extensions. The performance gain would be more than worth it for the small small change while driving around.
Old 03-01-2011, 10:15 AM
Ghost99's Avatar
ive heard going as big as a 3600 would make it feel "loose" driving normally with 2.73 gears though? also will i need a tune after doing this?
Old 03-01-2011, 12:22 PM
You should get a tune yes.
Old 03-01-2011, 03:51 PM
Ghost99's Avatar
so all i need for the install would be the yank ss3200, tranny cooler, and TCI flexplate if i wanted to and then get a tune and thats it?
Old 03-01-2011, 05:02 PM
01ssreda4's Avatar
Go 3600.......
Old 03-01-2011, 05:10 PM
Ghost99's Avatar
you think so? it wouldnt be annoying with 2.73 gears? it is my daily driver
Old 03-01-2011, 05:45 PM
lemons12's Avatar
The diffetence in town pick ups, below lock up which will be around 45, will be around 150rpms.. nothing you will ever notice especially if you have never had anything else. Once you hit lock up it will be exactly like stock.
The performance gain far far outweighs the small difference in town.
Old 03-01-2011, 05:49 PM
Ghost99's Avatar
ok so i guess i will go with a yank ss3600, tranny cooler, and tci flexplate. Does anybody know roughly how much it will cost to install all of that?
Old 03-01-2011, 06:10 PM
lemons12's Avatar
Completely depends on who does the work..100$-400$. I'd say 250 would be about right for most places.
Old 03-01-2011, 06:13 PM
Ghost99's Avatar
ok nice thats not to bad, thanks for all the help!
Old 03-01-2011, 06:55 PM
Quick Sh0t xMLx's Avatar
Like others have said you should go with a 3600. I would have gone with a 4000+ if I knew what I knew now(3.15 gears though).
Old 03-01-2011, 08:00 PM
9 Second Club/Nitrous Mod
shortdog's Avatar
Ghost, have your tuner adjust your shift points, rev limiter, turn off p0751 and/or p0757 codes and I recommend replacing your vehicle speed sensor also (only around $25). Those items can freak out the computer and make the tranny go haywire due to the higher stall.
Old 03-01-2011, 08:07 PM
Ghost99's Avatar
ok thanks, i think im just gonna stick with a 3200 stall i dont really go to the track often i just want something to wake it up and make driving more fun. what would be better to go with yank ss3200 or vigilante 3-disk 3200?
Old 03-01-2011, 08:16 PM
Before you make your mind up you need to talk it over with yank. You can get all the opinions on here but its piece of mind actualy talking with the stall builder. Give yank a call tomorro or call around to others as well. Also, seeing how you have a street car the SS series is gonna be the way to go.
Old 03-01-2011, 10:30 PM
lemons12's Avatar
With yank it would be the way to go.. I would also call ptc vig and circle d.
Chances are a vig3200 will be more like a 3400..
Old 03-01-2011, 11:59 PM
01ssreda4's Avatar
I say ditch the gears next. 3.73s or bust.
Old 03-02-2011, 09:08 AM
Slash8915's Avatar
I run the ss3200 and the giant tranny cooler. My car runs great. I also have 3.73's, but they were all installed at the same time, so idk if the gears made a difference or not. I know Lemons up there will tell you they don't. Lol.
Quick Reply: Newbie Help! Yank SS3200?
