LS4 Performance - Dod filter......important??
View Full Version : Dod filter......important??
crazyjoe
03-01-2011, 11:26 AM
After cutting the opsu neck to clear the ls1 intake, the little filter wont fit anymore, is this of major importance or can i run without it??
hazards280
03-01-2011, 11:52 AM
When we replaced the lifters in my car we ended up ripping mine. I went to the dealer and got a new one for like $6.
I don't know if it's needed but...It's called the "last chance filter" for a reason I presume.
DavidGXP
03-01-2011, 12:00 PM
I tossed mine. Not using DOD anymore.
crazyjoe
03-01-2011, 12:15 PM
Ill still be using my dod, i just want to make sure it wont blow up on the first crank lol. So, will i be "ok" to chance it?? Basically its rolling the dice so to say?
DavidGXP
Are you using stock injectors and rail?
crazyjoe
03-01-2011, 01:24 PM
Yes.....(filling space here)
DavidGXP
03-01-2011, 02:05 PM
Then keep the filter. I'd hate to hear of a collapsed lifter
hazards280
03-01-2011, 02:08 PM
http://www.youtube.com/watch?v=CcDOk9CrV6E
My Old Collapsed Lifter in the Back Bank
Haulin_Ls4_GxP
03-01-2011, 03:24 PM
You dont need that shit. A collapsed lifter isnt caused by a $6 filtet. Change your oil on time and you should be fine
DavidGXP
03-01-2011, 04:17 PM
He's talking about the filter inside the valley tray. It's there for a reason.
Not worth chancing having to pull the heads off over a 6.00 part IMHO.
DavidGXP
03-01-2011, 04:19 PM
Sounds like my engine last summer fter my first intake swap attempt:D
I had to pull the heads a replace the DOD lifters. PITA:mad:
hazards280
03-01-2011, 05:47 PM
I didn't say that it was the cause for my collapsed lifter, I was simply sharing what a collapsed lifter sounds like and my thoughts on the filter.
To the OP: Im sure you would be fine. I would really try to make it work as like I said earlier, it must have been put there for a reason. I am very cautious about the internals of my engine.
The collapsed lifter could have played a part in that :D 12 Hours of work and pulling a head, the Rear one at that has me on edge about everything.
On a side note, It's insane how light our aluminum heads are. I know it's obvious, their aluminum but....DAMN
