truck trouble
Old 03-01-2011, 05:15 PM
LooseMoose's Avatar
Default truck trouble
I have an 03 silverado with a 4.3. I can get it to start by holding the pedal to the floor, but after about 30 seconds it starts to idle rough and dies. Truck has had new plugs, wires, cap and rotor over last summer. Any ideas?
Old 03-01-2011, 05:54 PM
NW-99SS's Avatar
Sounds like a fuel issue. Low fuel pressure, dirty injectors, plugged fuel filter (which would give low fuel pressure).
Any codes? Misfire? Timing? Need to do a little more digging...
Old 03-01-2011, 07:37 PM
LooseMoose's Avatar
No codes, fuel pressure is 60 psi
Old 03-02-2011, 02:28 PM
Kevin@Vengeance's Avatar
Cat may be stoped up, take a compression gague and plug it in the o2 sensor hole in front and behind the cat and see how close they are. If the back is a lot lower, there's your problem
