What modifications will i need to do to run a double roller timing chain?
I have a ls2 out of a Trailblazer ss. and im wanting to know what modifications i will have to run a double roller timing chain. i here there will be troubles with the cam sensor and the timing chain cover... Does anyone have any expierance with this thanks.
You will have to do some grinding for sure. I am using the TF double roller and I spent some time grinding and welding. I don't have pics and I can't remember exactly what I did but I used clay to check the clearence till I had a good .200" clearance. The casting needs work on the back where it holds the crank seal.
