lt1 going ls1
Old 03-01-2011, 06:57 PM
greenlanternws6's Avatar
Default lt1 going ls1
Im having two much trouble with the harness in my lt1..As much as i love the lt1 im thinking of going ls1..I want to see if any of you have did it and was it worth the trouble of doing so .. I would love a lil advice .. I would have got rid of the car already but she two clean to part out as well as sell.. It almost looks new..
Thank ..
Old 03-01-2011, 07:10 PM
tricked94camaro's Avatar
so.... whats the problem?
Old 03-01-2011, 07:17 PM
jaycenk's Avatar
So swap harnesses. ALOT cheaper than doing a full on ls1 swap when you factor in that the trans, and K member will have to be adapted as well.
Old 03-01-2011, 11:24 PM
the_merv's Avatar
Here's some info..
https://ls1tech.com/forums/conversio...to-95-z28.html
Old 03-02-2011, 03:33 AM
Rockstar
Johnny-LT1-runner's Avatar
Why would you want to swap an LS1 harness onto an LT1 engine? That's not only pointless, but stupid and impossible as well.
What's the problem with your harness?
Old 03-02-2011, 03:40 AM
duh
duh's Avatar
The ls1 harness adapted to the lt is not impossible. Check out efi connection. Running the ls harness and pcm has numerous advantages over the lt pcm.
Old 03-02-2011, 03:45 AM
Rockstar
I'm talking minimal to no modifications.
Old 03-02-2011, 03:56 AM
duh
duh's Avatar
Either way it has advantages, granted most would not be usefull on a stock to mild engine, but they are still there. I agree in asking what's going on with the original harness first but swapping is always an option, albeit not the first thing I would do either ;-)
Old 03-02-2011, 10:10 AM
idformula's Avatar
So a guy could do an ls pcm conversion himself by swapping the harness and such? I know its not as easy as just plugging it in, but it wouldn't be much different than setting it up for an ls motor in an lt car, would it?
Old 03-02-2011, 12:31 PM
I had a diffrent post with the problems i was having .. Whats going on is that i get spark and fuel pressure but then it cuts off for some reason and does not come back on .. It works when it wants two and eveything is brand new from opti to fuel pump.. So im stump and feed up with the problem .. So i was thinking if i have to swap the harness might as well go ls1 or 6.0...I googled the hell out of this problem and cant to seemed to find a answer to it ..
Old 03-02-2011, 05:00 PM
Originally Posted by greenlanternws6
i had a diffrent post with the problems i was having .. Whats going on is that i get spark and fuel pressure but then it cuts off for some reason and does not come back on .. It works when it wants two and eveything is brand new from opti to fuel pump.. So im stump and feed up with the problem .. So i was thinking if i have to swap the harness might as well go ls1 or 6.0...i googled the hell out of this problem and cant to seemed to find a answer to it ..
vats?
Old 03-02-2011, 05:22 PM
the_merv's Avatar
Sounds like VATS.
Nope.
Old 03-02-2011, 05:27 PM
bypass the vats. its easy and its extremely cheap... $2 and 30 minutes for me
Old 03-02-2011, 06:11 PM
MattSapp95_T/A's Avatar
https://ls1tech.com/forums/lt1-lt4-m...l#post14580683
not an LS1 but it is an LS based motor...
Old 03-02-2011, 06:13 PM
how do i do that .. The guy working on the car was checking all that as well he made me get a new key for the car.... He also check the wires that go from the key switch to the box for the vats and fix all that .. I dont know if it matter if it was a 6 speed and the other owner made it a a4.... dumb ***.. but oh well...
Old 03-03-2011, 08:41 AM
the_merv's Avatar
Some people cant handle the Man Pedal.
Did it start after the A4 Conversion?
Old 03-03-2011, 11:11 AM
The guy said it did....but I doubt it.
Old 03-03-2011, 01:32 PM
do a search. plenty of threads on that.
Old 03-03-2011, 03:56 PM
the_merv's Avatar
It's a dark blue wire..dont really see it bein moved all that much unless they butchered the **** out of it..
Old 03-04-2011, 12:06 AM
Restricted User
jalper's Avatar
I think it is worth going to a iron block if you are on a budget, but to try to sell the LT is tough, as for the harness I think you could do the kit with the distributor and and most of the sensors might work out, but the best is to run a aftermarket harness, i have had a couple of done for sandrail project and they run about $300 if you can find a harness to have redone
Quick Reply: lt1 going ls1
