problems again
problems again
So I was driving my car last night and had s2000 try and a fly bye so punched it I let off at a 120 and was 3 cars in front of him I noticed when I let my belt squealed like crazy so I got on it again and noticed that it does it every time my car shifts at high rpms I also noticed that my voltage Gage is bowncing up and down like crazy any advice would help
Sounds like you've got a problem with either the belt or tension on it. That could be:
-Worn belt slipping at the RPM change, causing your alternator to dance
-Weak tensioner allowing belt slippage
-An accessory/ pulley binding due to bearing wear
Check the belt, pull it off, feel the pulleys and see if any of them have more than normal resistance or feel lumpy/ notchy.
