gear lash sound. Is it normal?
Old 03-01-2011, 10:02 PM
firebirdlover's Avatar
Question gear lash sound. Is it normal?
Hey All. I dont know if its a problem or not but I can hear the gears in my transmission/shifter at a very low almost grinding or gear mesh sound when driving in every gear and in neutral with clutch pedal being let out. Never gets very loud but I can hear it if I have the radio off. If I push the shifter around slightly also when in gear or neutral, it will sometimes diminish the sound a little. Sound like a particular bearing that might be going bad?
Thanks for the suggestions!
Old 03-02-2011, 01:43 AM
forecastvideo's Avatar
mine did that also. turned out my pilot bearing was demolished. it could also be something as simple as your factory shift handle rattling.
Quick Reply: gear lash sound. Is it normal?
