truck intake EGR
truck intake EGR
I started pulling the new motor apart and have a question already. On a truck intake when you pull off the EGR value it also attaches to the intake. I pulled it off but now is there a plate that I can make to cover the hole? Do you even need to cover the hole if not I will it looks bad. Also where can I get a photo of all the sensors and what they are before I start unplugging the harness I like to mark them
EGR Block off plate
GM PART # 12558346
CATEGORY: Engine Fuel Intake Manifold
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $22.03
PRICE: $13.06
EGR block off
Originally Posted by Cardinal Fang
Sensor location on 2000, 5.3 Vortec Engine
1 – IAC, Idle Air Control
2 - TPS, Throttle Positioning Sensor
3 – Evaporative Canister Purge Valve, remove
4 – Knock Sensor connector, sensors under intake manifold
5 - Map Sensor, Manifold Absolute Pressure
6 - Water Temperature Sensor
7 - Crankshaft Position Sensor
8 – Camshaft position Sensor
9 - Oil Pressure Sensor.
Not shown here
MAP, Mass Air Flow Sensor, located on the air inlet tube, removed
VSS, Vehicle Speed Sensor, after market purchase, JTR,
and others sell them
Oxygen Sensors, Vortec has 4, two before the cat and two after. Pre cat O2 sensors will be used
Oil Pan Level sensor
Not shown here
