Diamond Stage 1 & dowel pin question
Old 03-02-2011, 07:31 PM
hiltsy855's Avatar
Default Diamond Stage 1 & dowel pin question
I'm trying to install a Diamond Stage 1 (Luk) on my re-surfaced LS1 flywheel, and the pressure plate does not have any holes for the 2 dowel pins in the flywheel. Do I just remove the dowel pins & bolt it up? The bolt pattern is correct. The pic of the PP here doesn't show dowel pin holes either.
Old 03-02-2011, 11:28 PM
dgcustomz's Avatar
Just remove the dowel pins.They are not needed. Use the clutch alignment tool and set it up. That easy.
Old 03-03-2011, 08:13 AM
therealcreeper's Avatar
yep you have to remove them for Diamond's pressure plates
Old 03-03-2011, 12:18 PM
hiltsy855's Avatar
Ok, thanks.
Old 03-05-2011, 08:33 AM
Circa307's Avatar
i just marked and drilled holes into my clutch. before i did it i called jason at TDP bc i was afraid it would through off the "balance" of my clutch. jason said that it would be ok, so i drilled mine to match the pressure plate and it works perfect.
i did it this way bc i didn't want to remove my "torqued" pressure plate for a third time. now, if i had the PP off the block i would have removed the pins.
Quick Reply: Diamond Stage 1 & dowel pin question
