oil leaking between engine and transmission
By your statement of it being oil, my best guess would be the rear main seal. However, if it's a thicker oil it could be trans fluid... or potentially engine oil in your transmission.
Regardless of which, THErobertH is spot on. Definitely want to get that checked out ASAP.
It could possibly be the oil pressure sending unit or maybe even the crank position sensor. The OPSU in at the top back of the engine behind the intake manifold. The CPS is somewhere on the back of the engine, I think.
The OPSU would cause an almost equal leak down both sides of the bell housing, wouldn't it?
OP needs to determine where the oil/fluid is mostly leaking down to and from That'd be the only semi-accurate way to help find the potential cause. I would definitely consider the rear main and OPSU. The CKP I wouldn't think of as a top suspect, however I suppose anything can leak from anywhere.
I think the only way to really tell is pull the trans off. If you see no fresh oil coming from the top of the motor and see just a trail from behind the pressure plate its the rear main seal. When you put everything back together make sure you have someone check your pinion angle and. Could also be an input shaft seal on the transmission.
