Pretty sure my converter isn't locking up...how to make sure that is the problem?
It seems like my converter isn't locking up...My car is at higher rpms in 4th than it used to be and there is no "lockup" feeling when I hit the right mph. How can I make sure it is the converter before I pull the tranny out
Moderator
You should get it scanned while driving, look at TCC_Mode
for "intention" and TCC Slip RPM for "result". Look for tranny
slip codes that would prevent it from trying. If it says "locked"
and isn't, then look to your line pressure and TCC duty. But
that converter series (TCI Streetfighter) has some of the most
wimp clutches around. Once they slip, they loves to slip.
