th400 cluth engagement wires
I am swapping from a m6 to th400 I was wondering what wires on the clutch pedal that you cross to make it start?
also, I have a switch panel, and a empty switch I was wondering if I ran the wires couldnt I just use the switch like the stockish setup??
thanks
ed
firebird455@onebox.com
thanks
ed
The Bull
You splice the lower clutch switch wires into the neutral safety switch ot make it start. Reverse lights are a different story. Sorry, I got a little confused with your question about the switch panel. What are you asking about?
the shifter that I have doesnt have the neutral saftey switch.
So I was wondering if I could just run the wire to a panel where I allready have switches?
I dont really care about the NSS, so I was wondering the switch panel is allready in place.
also is there only one wire down there by where the clutch pedal plugged in? I honestly dont remember
thanks
ed
thanks
ed
