Got some free heavy duty wire. Is it good enough to use for the BIG 3??
Old 03-04-2011, 12:01 AM
joelx21's Avatar
Default Got some free heavy duty wire. Is it good enough to use for the BIG 3??
I work in an elementary school and the idiots that have some kind of heavy machinery business tossed a bunch of wire into our field. It looked very thick, so I decided to bring it home and see if I could possible use it for the BIG 3.
Originally, I was going to go with 0 gauge. How does this wire compare?
All 6 cables are from a company called Cobra Wire and Cable Inc.
Here's the link that will give you the specs for both cables.
http://cobrawire.com/products/battery.php
I have two 3/0 AWG cables Voltage: 600:
- 5 feet 1 inch
- 3 feet
I have four 1 AWG cables Voltage: 600:
- 4 feet 8 inches
- 4 feet 6 inches
- 3 feet 9 inches
- 3 feet 9 inches
Which wire would be the best?
0 Gauge wire?
3/0 AWG wire?
1 AWG wire?
Thanks,
Joel
Old 03-04-2011, 12:57 AM
99Bluz28's Avatar
Do you have a stock or High output Alternator? IMO, if you stock and plan to stay that way then use the 1 AWG; still overkill! If you've got a over +200AMP alt & big wattage stereo then use the 3/0 AWG for the alternator to + battery terminal, and depending how much is left use it for the -battery terminal to ground, use the 1AWG for everything else.
Old 03-04-2011, 10:45 AM
01ssreda4's Avatar
Use the 1 gauge.
Old 03-04-2011, 10:53 AM
safemode's Avatar
And always use the same gauge on both battery terminals. Current in equals current out.
but yea, 4 gauge would probably be plenty thick depending on how many strands the wire is and if it was copper or not for the stock alternator max output.
