Is the LS6 cam better than the LS1
Is the stock ls6 cam and springs better than the stock LS1 camm and springs or are they the same. if they are, How Much? here is the info i could find on the cam but im not that good on looking at the numbers yet can anyone tell me if there any good .550"intake and exhasut lift-218 degree exhaust duration, and 204 degree intake duration at .050, and 117.5 degree lobe centers also is it worth buying one or going with an after market i can get the cam new for $189
from the info i've been gathering about cams, the LS6 came makes its power in the upper RPMs. i've read that you pick up around 30 rwhp from the cam. i'm not sure about the springs though.
cam shaft
SN95 Director
Originally Posted by poncho99
dont waste the money on the cam i have one right now in a99 t/a it's comming out with in a week or two cant tell any difference at all.
the ls6 cam aint my style but its a great plug and play cam that requires minimal tuning if any and has greater top end pull provided you raise your rev limiter to obtain it.
Originally Posted by jrp
did you raise your rev limiter? if not then of course you wont notice a gain as the ls6 cam peaks alot higher then the ls1 cam.
yes i raised the rev limiter to 6500 even had it dynoed still wasn't impressed with the # went from 303 to 311 rwhp.that also with slp lone tubes no cats and a ls6 intake.
I bet its off as well or your running about 10.0 Air Fuel ratio.
Lean that bitch out, and if that isn't the problem then your cam is probally off.
I have seen 3 installs in person and the least amount of power picked up was 20 RWHP. The whole curve had more power as well.
I have also seen at least 8 header install's, probally 5 being LT headers. The least amount of gain here was 17 RWHP through stock exhaust. Highest was nearly 40 but that included exhaust at the same time. Avarage is about 21 I would guess.
As far as the Z06 intake goes I have only seen 2 guys do these without anyother mods being done at the same time. A gain of 4 on one and 7 on the other.
If you take all the lowest numbers I just wrote about you would have gained 41 RWHP.
Something's way wrong
I have this cam an it was a hell of alot more than a 11 rwhp gain. I had it tuned with the Predator and the difference was of "holy ****" caliber. I felt a increase starting at 4,000 rpm and 5,000+ is just nuts compared to the stock truck cam. Kinda wierd watching it shift at 6,500 rpm, but it makes power all the way to it. I have no regrets.
