putting a ss3600 converter in before cam hurt??
Old 03-04-2011, 05:03 PM
vbls's Avatar
Default putting a ss3600 converter in before cam hurt??
i need to replace my rear main and while the trans was out i was going to put in a shift kit, and a YANK ss3600 converter in.
nitrous, long tubes, 3.73 gears, weiand intake, spraying 150.
it will be like this for a little while before i do heads, and cam, or will this kill the car..?
Old 03-04-2011, 05:29 PM
ws6fitz's Avatar
No, it wont kill the car. I would say go for it. Even on a stock car you are going to see gains over the large stock stall.
Old 03-04-2011, 05:44 PM
henry172's Avatar
Yes it will destroy your car don't do it; just sale me your stall No but seriously you should be fine and actually notice a gain over the stock stall, I say go for it and I am sure others will say the same.
Old 03-04-2011, 05:53 PM
ULTIMATEORANGESS's Avatar
it wont kill it. it might break some stuff lol.
Old 03-04-2011, 07:45 PM
SS SLP2's Avatar
I ran a Yank ST 3500 for a couple of years on stock cam,gained about 1/2 sec just from the conv. was very subprized/happy
go for it, Johnny
Old 03-04-2011, 08:45 PM
vbls's Avatar
sounds good, im going to go with some 243 heads and just a torquer 2 cam later.
thanks
Old 03-05-2011, 01:05 AM
01ssreda4's Avatar
It'll be fine, a nice improvement.
Old 03-05-2011, 04:00 AM
MasterTomos's Avatar
Great gains even on a stock car. Plenty fine and common to do even to just a bolt on car. It will certainly make a heads/cam car more driveable/streetable as well as fast and fun too.
Old 03-05-2011, 06:32 AM
Restricted User
Vortech Converters's Avatar
It will change the way you feel about the car for sure. That's right were I start lsx converters. Throttle response, wot runs, overall seat of the pants feel is great. 3600 is great for stockers to bolt on's.
Old 03-05-2011, 07:03 AM
dlk1950's Avatar
Do It...Don't forget a tranny cooler.
Old 03-05-2011, 07:36 AM
vbls's Avatar
awesome input, im doing the trans cooler before i even remove the trans. should i do anything else to the trans while its out, a mild rebuild??? theres some miles on it but runs strong still.
Old 03-05-2011, 11:13 AM
Restricted User
z99ls1's Avatar
How many miles? If under 100k I wouldn't touch the internals of the trans
Old 03-05-2011, 01:13 PM
lt1-xjs's Avatar
I have 6 years on mine with the stock cam, bolt-ons.
MYSTIC-1SC's Avatar
Youll see some good gains for sure with the new converter in.
Old 03-05-2011, 04:35 PM
vbls's Avatar
it has 130,000 miles, i wasnt doing a shift kit..cause of the miles
cant afford to replace the trans, will a converter kill it?
if it does i can still reuse the converter later right? it wont destroy it
Old 03-05-2011, 06:01 PM
firefighter813x's Avatar
My first real mods were LT's and a Vigilante 3600 in my old Camaro. Wow... it woke that car up! Best first mods by far.
I just read the last post and laughed. My transmission went out a few months after having the converter. The car had 110k on it at the time. I bought a RPM 4L65e and it was worth the $$. EVERY person I know that has had a 4L60e transmission in a Silverado or Lsx vehicle as replaced it at least once... I even had a good trans cooler too...
Old 03-05-2011, 08:59 PM
garygnu's Avatar
if you have a good friend who works on trannys install some new clutch pacs and inspect the inners.and consider a deeper pan.if your trans fails have the converter and lines flush out,and change the filters a couple of times with in the 1 100 miles.
Old 03-06-2011, 05:55 AM
vbls's Avatar
where would i get a clutch rebuild kit?
well im guessing with my miles, its pointless to even put a converter in it, without doing a rebuild
Old 03-06-2011, 08:23 AM
WHPLASH's Avatar
The Yank SS3600 is a great choice. You'll see some nice gains all around. I would recommend freshening up the tranny (as mentioned above) along with the Trans Go shift kit. Tranny cooler is a must. The convertor and shift kit alone will amaze you!!!
Old 03-07-2011, 03:18 PM
vbls's Avatar
what exactly do i do if i freshen it up? a total rebuild kit? thats about 900 bucks..
Quick Reply: putting a ss3600 converter in before cam hurt??
