4L60e sounds
Old 03-05-2011, 01:08 AM
Slo TA's Avatar
Default 4L60e sounds
hey guys i had my trans fully built about ehh 1k miles back and well ever since when i come to a stop it feels like the trans shifts like back and forth like somethings loose??? is this just a 4l60e thing or what? this trans has best of the best everything has a 9clutch pack wich they only came stock with 6 shift kit servos brand new sprags and all. i thought it was my tourq arm mout the rubber boot because i busted one before and it made the same sort of noise so i did a polly one and still doing it??? i also have a 3500 stall. what you guys think i mean nothing is loose is it just the trans releasing on the inside or what?
thanks Andrew.
Old 03-05-2011, 11:03 AM
Moderator
Vince B's Avatar
What you are feeling might be normal depending on how the trans was setup. In some cases I have found with a superior billet second gear servo, case saver or a sonnax hd shift valve these coasting downshifts are more noticeable in the D3 position. HTH Vince
