TNT question Please Help!
Old 02-15-2004, 10:13 PM
LS1POWERHOUSE's Avatar
Default TNT question Please Help!
Is the only difference in the F1 kit and the F2 the pill size that comes with it?
I was wondering because I want an F2 kit but I found an F1, and if the F2 pills will work I will just order some F2 pills from TNT. Any comments or advice will be greatly appreciated. Thanks
Old 02-15-2004, 10:19 PM
blkbeaZ28's Avatar
That is the only difference. The pills, however you have to do a few more modifications if you want to pill up that high. I sent you a pm a while back on the one that I have. I am trying to go with a direct port.
Gilbert
Old 02-16-2004, 10:03 AM
NOTFAST's Avatar
also, you might wanna check the fitting off the filter if you are running more than a 150 shot
its supposed to be -6an off the filter (for 250+shot), instead of -4an which is on some older TNT set ups...simple fix with some aeroquip stuff
