Anyone know the stock diameter of 1995 LT1 Exhaust?
Old 03-05-2011, 01:13 PM
3ttamsivla's Avatar
Default Anyone know the stock diameter of 1995 LT1 Exhaust?
i'm looking to and a cut out where my cat was until I can afford a whole new exhaust. anyone know the diameter of the exhaust before and after the Cat?
Old 03-05-2011, 01:48 PM
riceburnerZ28's Avatar
It should be 2.75”
Old 03-05-2011, 02:11 PM
3ttamsivla's Avatar
okay thank you
Old 03-05-2011, 03:11 PM
MasterTomos's Avatar
as far as welding in a cutout, anything from 2.5inches-3 inches will fit in just fine. I have a 3" muffler and a 3" cutout in my I-pipe, which I believe is 2.75 inches before the muffler, 2.5 after the muffler(tailpipes)
Old 03-05-2011, 03:13 PM
transamws6_97's Avatar
unless the stock lt1 exhaust is different than the ws6...mine was 2.75 post cat also..i would go with 3" cutout but an easy way to measure your exhaust if you dont have calipers is take a piece of string and wrap it around your exhaust and mark where it overlaps...then just do some simple math and you can figure out the diameter
Old 03-05-2011, 03:14 PM
RamAir95TA's Avatar
Mine was also 2.75".
Old 03-05-2011, 09:37 PM
shbox's Avatar
2.75" stock after cat on mine, too.
Old 03-06-2011, 07:51 AM
Rob
Rob's Avatar
WS6 got the same exhaust as any other LT1 Formula or Trans Am. Only the tips were different.
Old 03-06-2011, 01:04 PM
I'm not positive if it was the Firehawks only, or the ws6's as well, but I believe a 3" catback was offered on some SLP Firebirds like they were on the Camaro SS's as an option SLP dual/dual setup IIRC
Old 03-06-2011, 05:43 PM
Rob
Rob's Avatar
Only the Firehawk and SS could get the optional 2OTL or dual/dual(97). SLP WS6's only came with the stock exhaust.
Quick Reply: Anyone know the stock diameter of 1995 LT1 Exhaust?
