ls3 injector pinout
Old 03-05-2011, 03:43 PM
rp0029's Avatar
Default ls3 injector pinout
I'm modifying an lq4 harness to handle ls3 injectors. I got these injector connectors, but which wire is for signal and which one for +12v?
Old 03-06-2011, 12:29 PM
rp0029's Avatar
Bump.
Old 03-06-2011, 12:31 PM
SweetS10V8's Avatar
Isnt the injector labeled (+) and (-) somewhere?
Old 03-06-2011, 05:28 PM
rp0029's Avatar
No. Any ideas?
Old 03-06-2011, 06:05 PM
01cherryreds10's Avatar
Pink is 12V, the dark green/black is ground. The LQ4 harness the topmost wire looks to be a faded pink wire, so that's 12V and the white is ground.
What's the LQ4 harness off of? I looked at a couple LQ4 diagrams and can't see any with white ground wires for the injectors.
Rick Speed's Avatar
Pin #2 is the control from PCM, Pin #1 power
Old 03-06-2011, 06:58 PM
rp0029's Avatar
The lq4 connector is on the left. On the right is an ls3 connector I got on eBay. The color of the ls3 may not be accurate. Which is pin 1?
Old 03-06-2011, 07:23 PM
Rick Speed's Avatar
They should be numbered. Look at the top by the wires it should be numbered. I just bought the same connectors you did but have not started wiring yet. If need be I can run out the the garage and look at mine.
Old 03-06-2011, 07:36 PM
Rick Speed's Avatar
Ok all the white ones are power and the multi colored ones are pcm.
Old 03-06-2011, 07:43 PM
rp0029's Avatar
I see an "A" and a "B". No 1 or 2 anywhere.
Old 03-06-2011, 07:44 PM
rp0029's Avatar
Great! Thanks!
Old 03-06-2011, 09:47 PM
Rick Speed's Avatar
A=1 b=2
Quick Reply: ls3 injector pinout
