lt1 wont start
lt1 wont start
ok so i built my lt1 and had it tuned by lt1 dave in milford, the car ran its *** off and like a week later i popped a coolant hose and fouled my opti also destroyed my map and icm needless to say i replaced the icm, map, opti, water pump, and coolant temp sensor. well car still wont run it cranks and sometimes hickups through the intake i treid a different pcm and no change in luck all wiring looks good and compression is up there too so i'm at a loss and dont know what to do it did have a bad fuel pump fuse but still no luck let me know what i can check next
