Upgrading to aluminm heads from cast iron heads?
Old 03-05-2011, 10:02 PM
MAROBOY_TRAV's Avatar
Question Upgrading to aluminm heads from cast iron heads?
I just purchased another camaro.. Its a 1994 ragg top z28 and of course it came with cast iron heads.. My buddie has a pair of aluminum 1997 z28 35th anniversary heads that hes sellin for a little bit of nothing.. What is the major difference between the 2? Besides the weight.
Old 03-05-2011, 10:31 PM
robsquikz28's Avatar
alum. will bump up the compression 1 point. Its a great mod over cast iron
Old 03-05-2011, 10:32 PM
jester1614's Avatar
the iron heads actually flow slightly better than the aluminum ones, the main benefits are weight and the fact that the aluminum heads dont heatsoak as badly as the iron ones. that and they are way easier to port lol
Old 03-05-2011, 10:35 PM
lt1-xjs's Avatar
All f-bodies came with aluminum heads. The motor must have been replaced. I'd make sure it's not the L99 first.
Old 03-05-2011, 10:47 PM
jester1614's Avatar
good point.
i have never heard about the aluminum heads having higher compression than the iron
Old 03-05-2011, 11:03 PM
Its a ragg toipp.. The casting numnbers came back as cast iron.. And im sure no aluminum heads are this heavy..
all f-bodies came with aluminum heads. The motor must have been replaced. I'd make sure it's not the l99 first.
Old 03-05-2011, 11:16 PM
SexyTransAm's Avatar
lol
Old 03-05-2011, 11:58 PM
jester1614's Avatar
no lt1 fbody came with iron heads, either the heads were swapped due to the original ones were warped or cracked, or the whole engine was swapped out with a motor out of a caprice or impala as those were the only ones that had iron heads.
one more difference between em is that the iron heads are straight plugs ie ! ! ! ! and the aluminum ones are angle plugs ie \ / \ /
Old 03-06-2011, 03:18 AM
93Z2871805's Avatar
Does it say '327' on the side of the block?
Old 03-06-2011, 03:23 AM
jester1614's Avatar
or 5.7 on the drivers side above the flywheel behind the head
Old 03-06-2011, 07:01 AM
96capricemgr's Avatar
The stock compression difference between the iron heads and aluminum head motors is .4. The iron head motor was 10.0 with a .029" gasket, the aluminum head motor was 10.4 with a .049" gasket.
Most definitely NOT worth the effort to swap stock for stock and the 97 heads are probably the 571 casting which is the worst of the aluminum heads as cast and for porting.
If his heads are 643 or 374 you might grab them for later porting but still I wouldn't bother swapping stock for stock.
Far as the L99 thing, it says 588 in the location that guys are asking about 327 in, BUT there are places it says 327 so the best way to go about it is going to be look back by the bellhousing for 4.3 or 5.7.
Quick Reply: Upgrading to aluminm heads from cast iron heads?
