v6 firebird not getting fuel or spark
Old 03-06-2011, 02:30 AM
1C3 MAN's Avatar
Default v6 firebird not getting fuel or spark
Hey guys i know this forums is for the LT1s but i cant figure this out.
i recently got a 1995 v6 firebird and the guy i bought it from said the fuel pump went out. And upon checking i found out that yes the fuel pump is bad but theres no power going to the fuel pump and its not getting any spark either.
i have check all the wireing and had to redo alot of it because someone tried to wire an alarm and did a very poor job. i also replaced the fuel pump relay,ignition module, and pcm. but still nothing.
any ideas guys? this has really stumped me
Old 03-06-2011, 09:28 AM
shbox's Avatar
Crank sensor, fuses, wiring needs checking. Some schematics or factory service manual would probably be helpful.
Old 03-06-2011, 01:16 PM
1C3 MAN's Avatar
forgot to mention i changed the crank sensor and all the fuses. and the wiring is back to factory it took me three days to go over it all.
anything els?
Old 03-07-2011, 12:46 PM
1C3 MAN's Avatar
anyone?
Old 03-07-2011, 03:09 PM
ss.slp.ls1's Avatar
Originally Posted by 1C3 MAN
anyone?
Probably because this is a LT1/4 subforum, not v6 forum, you might want to check their. As Shoebox mentioned, it might be worthwhile to pick up a repair manual and refer to the troubleshooting section.
Old 03-07-2011, 10:36 PM
1C3 MAN's Avatar
Is there a v6 forum? i looked and can't find one.
Old 03-07-2011, 10:51 PM
1C3 MAN's Avatar
I found v6f-body but its not very active. someone on here has to have some experience with the v6s
Quick Reply: v6 firebird not getting fuel or spark
