Yank STR to Stall ratio chart
Old 03-06-2011, 10:05 AM
Yank's Avatar
Default Yank STR to Stall ratio chart
Originally Posted by Yank
The stall torque ratio is the multiplying effect the converter produces on engine torque between the engine and transmission
on the initial movement of the vehicle, i.e. A stall torque ratio of 2.0 on a 400 ft. lb. engine will produce 800 ft. lb. at the transmission
input shaft on launch. So the higher the stall torque ratio, the higher the torque and harder the initial launch will be. This means sticky
tires will be required to maintain traction on the higher stall torque ratio converters (2.2 and above). Due to the new manufacturing process,
Yank Converters have a higher efficiency than the competitors. Don’t let the stall torque ratio be the only deciding factor on your converter
selection and feel free to contact Yank with any questions.
("*" denotes stock converter)
Thanks for looking
Old 03-11-2011, 03:26 PM
Yank's Avatar
up we go
Old 07-28-2011, 01:03 PM
Yank's Avatar
to the top
Old 07-28-2011, 01:29 PM
LS1_K1DD's Avatar
Nice write up and put together. Have always been curious about this. I will be picking up another converter from you guys here shortly! Love Yank, will never buy a different converter after my last SBS 3800.
Old 07-28-2011, 04:37 PM
drone's Avatar
I like my PT4000. Pulls well.
Old 07-28-2011, 11:53 PM
senicalj4579's Avatar
If I were to do it again I would get the pt
Old 07-29-2011, 12:29 AM
01ssreda4's Avatar
Told ya so
Old 07-29-2011, 10:06 AM
Originally Posted by 01ssreda4
Told ya so
Sure did and others did too. But now I know that its easy stupid to drive a 3600. Ill probably wait till the next trans to get a different stall though.
Quick Reply: Yank STR to Stall ratio chart
