"short ram" intake setup?
Old 03-06-2011, 05:12 PM
Jake_the_Snake's Avatar
Default "short ram" intake setup?
was curious if anyone has tried this type of air intake setup. need to get a new filter for my k&n elbow and thought i might give this a shot. it would make sense that it would be better, seeing as it is more direct and all, but i was wondering if i would have problems with the maf and the iat sensors. any info is appreciated.
Old 03-06-2011, 05:42 PM
96capricemgr's Avatar
If the filter has an inverted cone in the end and the engine tries to move air the MAF readings will be inconsistent. A VERY similar filter setup is quite common on the b-bodies, only we have a couple sheilds available to keep the hot underhood air out and just pull from over the core support.
I found a single short cone to be a little restrictive unless perfectly clean so I bought a cheap ebay dual cone setup to put in my scoop.
http://s120.photobucket.com/albums/o...t=DCP_0549.jpg
Here is the "scoop" I run.
http://www.impalaperformance.com/products.php
You could bend your own from sheet metal, or VFN has a trim to fit fiberglass one, there is also a polycarbonate one available.
As is your will suck all hot underhood air, not ideal.
Old 03-06-2011, 09:33 PM
hitmanws6's Avatar
Will hurt you more than anything, stay away from doing that
Old 03-06-2011, 09:44 PM
05HD's Avatar
Ah, the ever popular hot air intake mod.
Old 03-06-2011, 09:48 PM
meine96ws6's Avatar
anyone have real data to back up if this would work? i doubt you would gain anything.
i mean your car will only "suck" in so much air
Quick Reply: "short ram" intake setup?
