larger duration EPS numbers?
Old 03-07-2011, 11:43 PM
02sslayer's Avatar
Default larger duration EPS numbers?
im looking for people that have a larger duration EPS cam. high 230s-mid to high 240s duration. i wana see some dyno numbers for these cams. the smaller ones make such good power, i bet the bigger ones are just crazy!
so post your results please.
Thankyou, joseph
Old 03-08-2011, 12:01 AM
*02WS6TURK*'s Avatar
Joe wants a EPS cam lol
Old 03-08-2011, 12:04 AM
AINT SKEERED's Avatar
I started working on installing my 238/250 .603/.596 110+4 eps cam today in my nova. Damn pen magnet broke off on top of a lifter though. May have to pull head to get it off. If i do, im just gonna freshen up the rings while im that far
Old 03-08-2011, 12:21 AM
02sslayer's Avatar
what size motor is this cam going in? let us know how it turns out
Old 03-08-2011, 12:22 AM
02sslayer's Avatar
yes i do want an eps cam. but not in my LS1, i want one in a 402ci motor. or whenever i get my 2006 GTO
itsslow98's Avatar
Im doing the 234/246 in my 93 coupe, waiting for it to come in though so i wont have dyno numbers for about a month, he said i should easily see over 400 with stock 241s and ls6 intake.
Old 03-08-2011, 12:40 AM
347 CI. 8" STALL, 2600 lb car
Old 03-08-2011, 12:42 AM
02sslayer's Avatar
cool, looking forward to see what that beast puts down. im goinj eps on my next motor
Old 03-08-2011, 06:31 AM
-Q-
-Q-'s Avatar
I'm subbed for this as well. I have an EPS .238/.242, .604/.605 on a 112+4 going in an LQ4 shortblock with PRC 2.5 LS6 heads as we speak (rest of combo is in sig). Hopefully I'll have the motor and trans back in the car within a week, and everything running and tuned in the next 2-3.
Old 03-08-2011, 06:55 AM
00 black ss's Avatar
I shuld be getting mine tuned in about a month just waiting for a 9inch. My eps is a 240/256 in the .640s lift on both and 111lsa for my 383
Old 03-08-2011, 07:14 AM
firefighter813x's Avatar
62cc heads on top of the lower compression LQ4 gives you around 10.5:1? If so, that's a lot cheaper and easier than finding a LQ9. Very interested to see your results.
Old 03-08-2011, 07:55 AM
Demonicbird00's Avatar
i have a 245/250 .611/.615 110+1
456/408
-brandon
Old 03-08-2011, 08:53 AM
LS1 Tech Administrator
Patrick G's Avatar
How about 503rwhp with a cam/bolt-on LS2?
https://ls1tech.com/forums/dynamomet...s-503rwhp.html
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 03-08-2011, 08:59 AM
odarabla's Avatar
If you are gonna get one of Goeff's cams for a 402ci just spend the extra $25.00 and get a custom cam cut for it. This is to make sure you are making the most power with your setup. Or you can get Patrick G to spec it for you. Good luck.
Old 03-08-2011, 09:24 AM
Moderator
JayplaySS's Avatar
This is also my 1st choice for my C6, get on it man!
Yes sir, this is my 2nd choice with a slight revision for ported 243's.
Old 03-08-2011, 09:34 AM
odarabla's Avatar
Stroke the motor in that thing man..
Old 03-08-2011, 09:53 AM
87silverbullet's Avatar
I had a cam spec'd by Geoff for my 416 and its 240/251 637/620 114. Motor is still being put together by engine builder. Hopefully to have my car running by the summer. The cam is more for the nitrous also.
Old 03-08-2011, 09:58 AM
Factory 65-66 cc heads on a lq9 give you 10.5:1 so It will be more like 10:1 with an lq4
Old 03-08-2011, 10:36 AM
-Q-
-Q-'s Avatar
Yes indeed, and that's with a stock head gasket.
I know! I'm trying not to rush getting everything back together, but man am I ready to have this build done.
Old 03-08-2011, 10:45 AM
kinglt-1's Avatar
I have seen a few bigger duration(236+) eps cams posted in the dyno section over the last year... gains are not as impressive as the 22x in a stock headed ls1... must be deminishing returns caused by the stock heads. I wouldnt ever go into the 230's unless I had a killer set of heads anyways.
Quick Reply: larger duration EPS numbers?
