dot com... AN FITTING DIRECT ????
any one use them? they say that their lines are chemically the same as TEFLON lines
the lines and fittings look good and cheap...... almost too cheap...
i know i will get the you get what you pay for from some people
but there are also places that make to much of our hard earned cash because they dont have " the name brand" competition...
input please!!!!
LS1TECH Sponsor
Not sure what "chemically the same" means. Either they are Teflon or they are not.
Their rating is not as high as other teflon lines so it may be thinner or weaker.
The hose I use is rated for approx 3000psi, so I would assume there is a significant difference somewhere.
I can tell you that the correct PTFE (teflon) hose for fuel is not white, it is carbon impregnated black. The conductive black line is the only proper fuel rated hose. Use others at your own risk.
Kleeborp the Moderator™
Interested too, nearly half the price of what I put together at Summit, only downside is their selection of adapters isn't all there. Plus it says "These Aluminum Fittings are specially designed to work with our Braided Stainless Steel Lines." If this stuff isn't the best, it sounds like the entire system is gone, no re-usable components with other lines. Nor would any other AN fitting work with this tubing. Maybe it will, but doesn't sound promising.
MEENTSS02 hit it on the head the tread mark thing can be a pain sometimes.. specially when that name is the common name used..
thanks for the input guys... same feeling i had but its sometimes the ones you never heard of that others swear by...
anyone else?
anyone else?
so you wouldnt use it? it would just be used in a mild single turbo build but that is the 1st i have heard of some one using them..
more details if you dont mind....
thanks
thanks
http://www.summitracing.com/parts/AER-FCC0620/?rtype=10
This is the line i bought since its not black it isnt rated for fuel?
I can tell you that the correct PTFE (teflon) hose for fuel is not white, it is carbon impregnated black. The conductive black line is the only proper fuel rated hose. Use others at your own risk.[/QUOTE]
