tps
Old 03-08-2011, 03:47 PM
93z28ltone's Avatar
Default tps
I put a new tps sensor on my car and now when I want to open it up full throttle I feel like I'm having to push the gas threw the floor board any suggestion
Old 03-08-2011, 04:09 PM
RamAir95TA's Avatar
Be more specific. Have you checked your new TPS for proper voltage at closed and wide open? Why did you need a new TPS in the first place?
Old 03-08-2011, 05:51 PM
93z28ltone's Avatar
My old one was bad and no I haven't how do you do that
Old 03-08-2011, 07:42 PM
RamAir95TA's Avatar
How did you know your old one is bad?
Stock voltage with the key on, engine off on the blue signal wire should be between .2v and .9v (ideally ~.6v) at closed throttle and increase proportionally with throttle position about four more volts.
What do you mean "I feel like I'm having to push the gas threw the floor board." You need to be WAY more specific in order for us to help you. Specifically, how is the car acting?
Old 03-08-2011, 07:56 PM
93z28ltone's Avatar
I mean when I floor it I have stand on the gas pedal for it to hit wot and the other sensor was cracked were you plug into it
Old 03-08-2011, 09:47 PM
jaycenk's Avatar
Have you checked to see if the tb blades open to WOT by hand? Also have you checked to see how far they open when you "Put it through the floor board"?
Old 03-08-2011, 10:36 PM
93z28ltone's Avatar
I will check it tom when there's light out side
Old 03-08-2011, 11:25 PM
93Z2871805's Avatar
Did it only start happening after you changed the tps, or did it do it before and that's why you changed it?
Old 03-09-2011, 01:05 AM
93z28ltone's Avatar
yes its been doing this since ive owned the car
Old 03-09-2011, 05:39 PM
93z28ltone's Avatar
Its opening almost all the way
Old 03-09-2011, 05:47 PM
93z28ltone's Avatar
When I push the gas peddle down
Old 03-09-2011, 09:09 PM
coolmanvette75's Avatar
almost isnt all the way... time to upgrade your throttle body
Old 03-09-2011, 10:56 PM
RamAir95TA's Avatar
Sorry but that's just WAY off and completely unnecessary.
OP, you need to check your TPS voltage before you do ANYTHING else.
Old 03-10-2011, 12:12 AM
93z28ltone's Avatar
need to find some one with a voltage checker and i will do that
Quick Reply: tps
