Thinking about doing a Lt/ORY install soon, but need advice.
Old 03-08-2011, 07:32 PM
99redrockett/a's Avatar
Default Thinking about doing a Lt/ORY install soon, but need advice.
Hey guys, so im thinkin about installing some LT's and a ORY to match it. My question is how hard is it to install the LT's, and how hard is it to delete the air pump? It looks pretty crammed in there, and just wanted to get some feedback. Thanks!
Old 03-08-2011, 07:39 PM
Michael Crisp's Avatar
installing LT's werent bad IMO i didnt remove much just unbolted the steering linkage and feed the headers up from under the car and had someone receive them from up top
Old 03-08-2011, 07:52 PM
Cool thanks for the quick reply! Did delete any of the emission components?
Old 03-08-2011, 08:12 PM
Sargeant Sh!tbag's Avatar
I didnt even have to remove the steering shaft on my old car with the pacesetter lt.. Very easy. IF you have a tall enough jack you will have this project completed in less than 3 hrs even if you have never done it before.. Just reuse your stock gaskets too.
Old 03-08-2011, 08:24 PM
did I delete any? if thats why you tried to ask then no
Old 03-08-2011, 08:51 PM
MikeWS6's Avatar
GM hightech has a few articles and they say plan on 12 hours. Mine took 8 in a shop on a lift
Old 03-08-2011, 09:09 PM
DukesOfHazard's Avatar
installuniversity says plan for 8 if you've never done it before. I've never done it myself, but I definitely want to.
Old 03-08-2011, 09:12 PM
SoWazIt2You's Avatar
I Just deleted my air and egr in preparation for my lt and ory. Pretty simple stuff. Will set ses light though just as a heads up. Air only took about 15 min to pull. Make sure you have block off plates or get lt without the hookup.
Old 03-08-2011, 09:15 PM
sjsingle1's Avatar
took me about 3 days......now i can do it in about 4 hrs..deleted EGR and AIR.....not that its hard.......you just go slow because you have never done it before
Old 03-08-2011, 09:24 PM
dannyo210's Avatar
I did my first LT/ORY/!egr/!air last year, also swapped the motor mounts out at the same time for some polys, which I definitely recommend doing. Get new GM manifold gaskets, NGK TR55 plugs, and new wires(I went with MSD's) too while you're at it.
You'll need to jack the front of the car up quite a bit to get the headers in. Deleting the emissions stuff isn't hard at all, but just know if it isn't functioning it will throw the SES light. You'll have to get at least a mail order tune to delete the rear O2 sensors and you can remove the emissions from the computer at the same time. Your car won't pass an OBDII inspection with these errors.
There's a couple really good threads on this forum that cover the install with detailed pictures. This is one of the best.
https://ls1tech.com/forums/generatio...otsa-pics.html
It took me probably around 12-14 hours total. A couple nights after work and most of a weekend to do the work all by myself. If you have some mechanical ability, the tools, and don't mind banging and scraping your knuckles then go for it. It's definitely worth it
Old 03-10-2011, 12:53 PM
GSus's Avatar
^^^this.
It took me 2 days. First day was MMs, and removing everything else prepping for headers. 2nd day was header and full exhaust install.
I was hurting from the waist up for about a week afterwards. My hands felt like they were completely useless during this time too.
Old 03-11-2011, 02:34 PM
Thanks everyone for the replies, ill keep all this stuff in mind. I went to school for auto/diesel mechanics so im pretty sure i have the mechanical ability
Old 03-11-2011, 04:53 PM
MikeWS6's Avatar
I wont lie its not a walk in the park. If I ever buy another ls1 it will come with them already installed. The motor mounts were probably the worse part.
Old 03-14-2011, 11:05 PM
00ws6indubv's Avatar
Hey man just installed my LT/ORY and deleted the AIR on my 02 ws6
Honestly I did NOT have to cut anything or unhook steering. If you get the car about two feet off the ground its not that bad. Just be patient take plenty of breaks and get a good buddy to help you. took me two days with lots of stopping to eat drink and drink some more lol. but anyways have the correct tools I even needed a 3/8th rachet a few times in tight spots it is very tight in places. Again slow and steady and it can be done. PS PB BLASTER on all the old bolts helps a ton def. do not wanna break off any bolts especially the header bolts. Oh and go ahead and change your plugs and wires while you are in there. AIR btw is simple just make sure if you have a 00 and up to plug up the vacuum hose with a little screw or something. Have fun and oh dont forget to start the car AFTER you install headers to hear the open headers IT SOUNDS WICKED!
Old 03-14-2011, 11:16 PM
WSsick's Avatar
It really isn't hard, just time consuming...unbolting everything and removing it. Take your time and it won't be too bad. I didn't need to touch the steering shaft, my cheap *** painted pacesetters slid right in.
Word of advice: do plugs/wires while you're in there if you are due for it. This will be the easiest plug change of your life, 1000x better than doing it once the car is back together.
Definitely not.
Old 03-15-2011, 02:52 PM
dodson55's Avatar
installing long tubes are not hard at all the big key is to get the car in the air at least 30 in or so or if you have a lift its a piece of cake
Old 03-15-2011, 03:46 PM
transamtom's Avatar
Just did mine on jackstands in my friends garage,it was easier than my 88 GTA SLP shorties and my 94 TA SLP shorties.
Old 03-15-2011, 05:02 PM
MYSTIC-1SC's Avatar
You shouldnt have a problem. Its a rather simple task.
Old 03-15-2011, 06:22 PM
stroked383HSR's Avatar
im subbin to the thread so i can use it when i do the LT ory....in the future!
Old 03-15-2011, 06:26 PM
GSus's Avatar
You need to 'scribe to this thread.... https://ls1tech.com/forums/generatio...otsa-pics.html
