Does it have a different gear?
So I just picked up my 95 T/A and Im pretty sure it has a different rear gear than stock. The car runs about 5mph over what the spedo is reading and the tires are not whats causing it to read wrong. The car pulls harder than any other Camaro or T/A Ive rode in.
Is there any calc out there to see what size gear im running rather than pulling off the diff cover?
A less accurate way that will get you in the ballpark is at 70mph auto drop out of overdrive and see what your rpms are. If it's a manual use 4th. That'll get you in the ballpark. The car going faster than the speedo reads suggests that you have a lower gear than stock. If you had a higher gear then the speedo would read higher than your actual speed.
I misstated what I said in the first post but that is right. The speedo shows 70 and I'm actually doing about 64 or 65. I run the car to 70 (75mph on the speedo) and I was running about 3200rpm. So 3:73?
Calculating differential ratio
Driveshaft goes around 3.42 times for the wheels (both of them) to go around once - 3.42:1. Driveshaft goes around 3.73 times for the wheels to go around once - 3.73:1. You won't be able to get the last decimal with any accuracy, but the difference will be about a quarter revolution of the driveshaft, which ought to be evident.
Best -- Gary
I have yet to see any problem, however complicated, which, when you looked at it in the right way, did not become still more complicated. -- Paul Anderson
Best -- Gary
